Back to Library PAGE
Page 1 - Page 2 - Page 3 - Page 4 - Page 5
Relay install tips for the 14 pin Relay and sockets
This is the schematic for the 14 pin socket -  small signal switching relay's that I no longer stock.
This is a relay power power supply board.
The white wires are the 6.3 vac coming from the amps heater supply.
To relay coil +
goes to the relay coil positive.
The relay coil minus is what you ground with a switch to turn the relay on.
I used 4700uf/25V caps because that's what I had on hand.
I stock 4700uf/16Volt caps to use on these relay power supplies.
This is the schematic for the 14 pin relay that I no longer stock.
The power supply board is shown above.
I have two 4700/16V filter cap and I have them separated by a 180 ohm 1/2 watt resistor.
The 180 ohm resistor drops the supply voltage to the relay down close to 5 volts.
Without out it I was closer to 7 volts.
You can adjust the value of this resistor to suit your particular amp.
@ MEMBER OF PROJECT HONEY POT
hand-mild
