Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 23, 2013, 05:18:00 am
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Holy Grail, Holy Hum!  (Read 525 times)
Dynaflow
Level 4
Offline Offline
Have a cow man!
« on: December 09, 2006, 11:10:11 pm »
 Ok, I've had this Holy Grail reverb from Electro-Harmonix for like a year (got it last Xmas) used it once or twice. It has the adapter that came with it. Reading its reviews on Harmony-Central (or Harmony Dewd Central as it were) and it appears its common there is a hum (sounds like power supply filtering issue) that gets so bad it almost makes it unusable. I hav'nt taken it apart yet, futzing with the P/S jack seems to make it quiet down (its still far from silent). Since this appears to be a common problem on these units, has anyway ran across it and found a good fix?
 On a positive note, when its not humming and you can get it to quiet down, it sounds extremely fine. I was playing 'Lenny' through it into the Superlead 100 at a apt. volume (WAY CLEAN) and it sounded so mighty fine. The flerb setting is a little weird, I guess useful in the right song. Anyway, any idea's?
Regards,
Dyna
Ps: It uses a 1/8 phone jack for the p/s adapter, a bit different than usual barrel type plug. It uses no battery at all.
« Last Edit: December 09, 2006, 11:19:34 pm by Dynaflow » Logged
EKDENTON
Level 3
Offline Offline
never goin back to solid state
WWW
« Reply #1 on: December 12, 2006, 05:53:26 pm »
i have one of those barrell type plugs that I soldered to a battery strap so I can run an external 9v battery on all my boxes. If you think it is the power supply maybe you could rig up a battery to the 1/8" phone jack just to see if running on a battey is quieter. It may suck alot of juice, maybe that is why they don't have it on a battery, but if you tried that at least you would know if it is the power supply.
Logged
let's rock
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #2 on: December 12, 2006, 07:12:22 pm »
 Yeah Ed, its my understanding it draws so much juice a 9v batter won't last very long at all.
Regards,
Dyna
Logged
rockgardenlove
Level 2
Offline Offline
I hate tube amps
« Reply #3 on: December 29, 2006, 04:36:57 am »
I'd say open it up and up the value on the PS filtering.
Logged
tubenit
Global Moderator
Level 5
Offline Offline
Life is a daring adventure or nothing at all!
« Reply #4 on: December 29, 2006, 06:19:08 am »
Dynaflow,
I had a Holy Grail that I used with a VibroChamp I used to own. It had NO hum to it at all and was very quiet. Had a great reverb tone, IMO.  I compared the reverb to my Princeton Reverb and view them just different without one being signficantly better than the other. I do think the Holy Grail sucked some of the tone of the amp away.
Have you tried it on different 117vac outlets to see if it still does it?
Logged
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #5 on: December 30, 2006, 02:15:08 pm »
 Yeah, does it at gigs (multiple) and at home. Its something that was mentioned in Harmony Central (I know not the resource for unbiased info) as a problem, many units sent back. I'll open it up and check out the filtering, it seems that diddling with the jack sometimes causes it to work ok. Its probably a easy filtering fix. I like the sound of the unit, its a awesome sounding reverb. It may suck tone, have'nt been able to use it long enough to tell, but then again I was using my 100 watt Marshall and its got so much punch its hard to tell sometimes... :D
Regards,
Dyna
Logged
jjasilli
Level 4
Offline Offline
Took the power supply test. . . got a B+
« Reply #6 on: January 06, 2007, 09:53:35 pm »
Dynaflow,
Same here, still have the pedal.  So does a friend of mine.  But I do hear the hum complaint from others now & then.
Logged
jzad
Level 1
Offline Offline
I love tube amps alot
« Reply #7 on: February 25, 2007, 03:57:26 pm »
 I have a holy grail that does the same thing did you change the filtering at all? Did you find a way to solve the problem?
Logged
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #8 on: February 26, 2007, 02:57:02 pm »
 Haven't looked at it yet, probably should now I'm between projects... Heck even if I had to put together another power supply instead of the wall wart I'd consider it, its truly is a great sounding pedal IMHO.
Regards,
Dyna
Logged
jzad
Level 1
Offline Offline
« Reply #9 on: February 26, 2007, 03:33:36 pm »
i just popped open the wall wart for the holy grail and it has a 2200uf 6v capacitor. I'm assuming this is a filter capacitor. Does anyone know if changing this value may make a difference in our hum problem?
Logged
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #10 on: August 31, 2007, 11:53:48 pm »
 Sorry this solution took so long to look into, those that have the pedal, or want to file it away for future reference. Its totally the power supply. Wife went back home to Texas so I had a bit of undisturbed free time, was jonesin' for some reverb and loved this one before it started giving me problems (almost immediately after purchase two xmas's ago). Was playing the 100 watt marshall cleanly and low (of course, hey I'm in a apartment, my neighbors love my playing, but not with that monster turned up) and decided I'd try it again. Hum started immediately. I jiggle the jack, had the thing open before, does'nt appear to be a problem. I figure what the heck, I have wall warts around, so I find a old Danelectro 200 ma 9.6 volter graft on the mini 1/8" plug onto it. Fire it up. Silence, perfect lovely reverb, no hum at all. So simple fix, should have gotten to it long ago, it truly is one of the better pedal reverbs I've heard. Does spring and plate and flerb (flanged reverb). The extreme in spring or plate gives that Led Zepelin almost reverse sounding reverb with a delayed attack thats really a trip. Soooo, looks like my amps will have reverb again and for that I'm REAL happy. And yeah, I feel like a horses ass for waiting so long to fix something so simple. :D
Regards,
Dyna
Logged
LooseChange
SMG
Level 4
Offline Offline
Keep it greasy so it goes down easy.
WWW
« Reply #11 on: September 01, 2007, 06:16:26 am »
Just like building amps... The power supply needs to be quiet!
My favorite reverb pedal is the Boss RV-2. It came out around 1983. I still got it and still use it.
It looks like all the modern Boss pedals... You know I can't believe it's that old!
Logged
Call me Dan
www.fydamps.com
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #12 on: September 01, 2007, 01:49:49 pm »
 I hear ya' boss, seems like the majority of amp building related problems is hunting down electrical noise from power supplies. I figured it was probably power supply related due to it being a 60 cycle hum, but figured I'd have to get creative with some filtering inside. Oh well, I guess wall warts do have some pluses (I'd almost like to mail this one to EH after running it over with my forklift at work). :D
Regards,
Dyna
Logged
duke of earl
Level 2
Offline Offline
Bird is the Word
« Reply #13 on: January 01, 2008, 08:53:42 pm »
I hate every EH pedal I've ever played. They all suck tone bigtime and yes they are all noisy. sorry to be so negative but the truth is the truth. I've got an old Clone Theory (70's) for sale if anyone is interested.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
