Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 21, 2013, 12:17:14 pm
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Micro drill press  (Read 673 times)
Tiny_Daddy
Level 4
Offline Offline
Get your Amp N Gear!
WWW
« on: December 04, 2006, 07:26:22 pm »
I am looking for a small non-dremel drill press for drilling holes in eyelet boards and sheet metal. Just something small and accurate, not a big floor model. Any favorites?
Logged
TubeGeek
SMG
Level 3
Offline Offline
WWW
« Reply #1 on: December 04, 2006, 07:29:39 pm »
I bought a Delta 10" table top drill press from Lowes for $99 for this same reason.  It works great.
« Last Edit: December 04, 2006, 07:30:45 pm by TubeGeek » Logged
mojo
Level 2
Offline Offline
your a superstar, how right you are- John Lennon
« Reply #2 on: December 04, 2006, 07:58:52 pm »
Harbor freight as low as $40.
Logged
sluckey
Global Moderator
Level 5
Offline Offline
« Reply #3 on: December 04, 2006, 08:02:21 pm »
"Delta 10" table top drill press from Lowes for $99 "
I have this also.
...Steve
Logged
tbeck
Level 3
Offline Offline
"Mars ain't the kinda place to raise your kids..."
« Reply #4 on: December 04, 2006, 09:28:27 pm »
I have a Sears 6 inch drill press about 10 years ago (when I had a Sears charge card)
It has just less than 4 inches of clearance from the drill chuck center to the main post that the assembly is mounted on, which means that you can't drill a hole 4 inches in from any edge. It works well enough for me, but a 10 or 12 inch is more useful for some things.
Logged
"Ignorance can be cured with education, stupid is forever"  Clint Smith--Thunder Ranch owner and instructor.
rockgardenlove
Level 2
Offline Offline
I hate tube amps
« Reply #5 on: December 04, 2006, 09:46:10 pm »
I really recommend buying some of the Unibit/Varibits.  They're awesome, you don't even need a drill press!
Logged
HotBluePlates
Level 5
Offline Offline
Learning the fine points of Thermionic Kung Faux!
« Reply #6 on: December 04, 2006, 10:11:40 pm »
I have the same or the next size up. Works like a drill press should.
Logged
From Principles of Electron Tubes: "... the phase of the output voltage is retarded."
gehicks
Level 2
Offline Offline
Migratory Engineer
WWW
« Reply #7 on: December 05, 2006, 12:02:59 am »
I have to disagree with that Harbor Freight thing.  I bought one and it promptly broke like the cheap plastic  toy it is.
Spend about $50 more and get a real tabletop drill press that won't break after one or two boards.
.02
Cheers,
Jerry.
Logged
mojo
Level 2
Offline Offline
« Reply #8 on: December 05, 2006, 12:06:23 am »
 ;D ;D ;D ;D ;D
gehicks, that's a good one. That's one reason I posted that was to get input on that thing. Like they say if it sounds too good to be true...
Logged
kriswel
Level 2
Offline Offline
I love tube amps and my wife still loves me
« Reply #9 on: December 05, 2006, 12:07:20 am »
rockn' the same delta.  does the trick.
kris
Logged
madison
Guest
« Reply #10 on: December 05, 2006, 01:42:01 am »
This is the peeve I have with the mini press I bought.
Not good if you wanted to sick a chassis or a wide piece of metal or wood in there.
I suppose I will have to get a bigger one eventually.
Otherwise, for the $60 spent, pretty okay.
Logged
gldtp99
Guest
« Reply #11 on: December 05, 2006, 04:08:40 am »
Great topic and info---- i've been considering getting a small drill press, also---- sounds like the Delta 10" is the one to get..........gldtp99
Logged
LooseChange
SMG
Level 4
Offline Offline
Keep it greasy so it goes down easy.
WWW
« Reply #12 on: December 05, 2006, 06:19:50 am »
I've got the $99 Ryobi 10" press. Home Depot has them. Solid unit.
Logged
Call me Dan
www.fydamps.com
johnnystomp
Level 2
Offline Offline
"He who dies with the most tube amps wins".
« Reply #13 on: December 05, 2006, 09:53:38 am »
When you are checking out a drill press for board making, take a good look at the press mechanism. Remember you will be using the press for drilling as well as setting eyelets and turrets. JS
Logged
..." God does not deduct from ones allotted time on Earth the hours spent amp building...or melting guitar picks trying to sound like Dick Dale".
EL34
Administrator
Level 5
Offline Offline
wooot!
WWW
« Reply #14 on: December 05, 2006, 04:30:10 pm »
The Delta drill presses work great.
I have three Delta drill presses here of different sizes.
I like the big mofo the best.
One old small Delta was turned into a permanant lug press.
I removed the motor to make a lug press.
I also had to prop up the drill platform with a piece of oak to keep it from bending down when I pressed a lug.
Logged
EKDENTON
Level 3
Offline Offline
never goin back to solid state
WWW
« Reply #15 on: December 05, 2006, 04:45:53 pm »
This one is a table mounted drill with a 1/2HP motor, and it occillates if you decide you need to do some contour sanding on something. Pretty good price too.
http://www.grizzly.com/products/h0625
Logged
let's rock
triode
SMG
Level 3
Offline Offline
Espresso. Now.
WWW
« Reply #16 on: December 05, 2006, 09:48:48 pm »
I am not trying to be a pompous ass, but I will say the following, having
worked in machine shops, a wood shop, a furniture making shop, and a speaker building
shop:
Buy the BEST damn tool that you possibly can with as much cash as you can
when you go to do it. You should _never_ say "what is the cheapest..." It is
always "I can eek out $482.39... what is the best damn drill press I can possibly
buy for that... let me go ask a WOODWORKING or METALWORKING forum". Go ask
someone who uses the drill press a 100 times a day, every day.
Consider this to be your warning against a $100 drill press, from the _MAN_ himself,
and I quote:
 "I also had to prop up the drill platform with a piece of oak to keep it from bending down when I pressed a lug."   -- Doug Hoffman
So, wait up.. you mean, if I am drilling something hard, like a chassis, the platform will
bend down slightly?? You know what that means?? More broken bits, more holes that are
not perfectly normal to the surface, more tube socket screws that go in at an angle and piss
me off to no end as I try to wrangle a nut on the other side as it is hitting the socket itself
(I had a friend get one of those cheap presses and saw him through this... heh).
Seriously though, ask any woodworker, metalworker, auto mechanic, etc... you know
why those guys pay $24.87 for a wrench??!? Because when they put a 10' cheater pipe
on it it does not break. You are going to use your drill press as a press... you are going to
press a LOT of turrets? You need more than the $100 model, trust me.
Just my $0.02, and hey, I don't know Jack Schidt. Or his brother.
Logged
johnnystomp
Level 2
Offline Offline
« Reply #17 on: December 06, 2006, 12:27:05 am »
"I am not trying to be a pompous ass"...
If you are , I guess I might be too. I used to do a lot of fabrication in the motorcycle business. I found out real fast it pays to get quality tools, and not necessarily in the long run. That's what my Snap-On man told me anyway. I just replaced a belt on my Atlas press...I had it 30 years without doing a thing to it. I thought it kind of funny that my belt broke so close in time to this post.
The Atlas isn't made any longer, nor was it in production when I bought it 30 years ago.
The only bad memory I have of it is the day one of my Lumbar disks squirted out to one side of my spine when I was carrying it across the shop and slipped of balance.
Oh yea, it weights allot.
I have a small turret vise mounted in it...It can crank all the way to a full 360 degrees and about 6" crosswise. Great for light milling It's all an over kill for board making, but you get the point.
PS: I put a pipe on an old Snap-On a day ago replacing a clutch on a Volvo with 200,000+ miles on it, and it was probably a first time replacement. What does that tell you???
« Last Edit: December 06, 2006, 12:37:00 am by johnnystomp » Logged
EKDENTON
Level 3
Offline Offline
WWW
« Reply #18 on: December 06, 2006, 12:57:49 pm »
An arbor press is a good alternative for pressing the turrets onto the board. You can get a 1/2 ton for about $50, and save the drill press for lighter stuff like drilling holes.
Logged
let's rock
tbeck
Level 3
Offline Offline
« Reply #19 on: December 06, 2006, 02:19:10 pm »
If you're gonna do lots of turrets, an arbor press is a good investment.
Logged
Tiny_Daddy
Level 4
Offline Offline
WWW
« Reply #20 on: December 06, 2006, 07:55:38 pm »
I have tried asking machinists, etc. but the drill press is not a priority with these guys and seems to be on the same level of consideration as the shop vacuum cleaner. They are way more concerned about that next 30" mill or crankshaft grinder. It seems if they need a super-accurate drilled hole they do not use a drill press. So thanks for all the input and I may head over to Lowes this Sunday. And maybe also get a press for pressing.
Logged
EL34
Administrator
Level 5
Offline Offline
wooot!
WWW
« Reply #21 on: December 07, 2006, 03:48:33 pm »
I use my drill presses alot, it's worth having at least one.
I don't think you have to spend $500.
Get a Delta at Lowes. The quality is fine.
If you use it so much, you need a better or bigger one, get a another press.
Use the old one for a lug press like I did or sell it to your neighbor.
Logged
TubeGeek
SMG
Level 3
Offline Offline
WWW
« Reply #22 on: December 07, 2006, 06:04:12 pm »
I have no bending or flexing problems with my delta.  It works just great.
Logged
Janitore
Guest
« Reply #23 on: December 07, 2006, 06:18:33 pm »
Lowe's is having thier Employee's 20% off Christmas sale Dec. 5th through Dec. 11th.  This is for Employee's only so get your relative or buddy that works there or favorite Lowe's employee to get you the additional 20% off (they normally get 10% off year round).  Let them buy it for you, but with cash money, you don't want them to get fired!  One drawback though, if it breaks under warranty your reciept will have the employee's name on it making the return/repair questionable if the original purchaser doesn't return it.
Just a thought.  I'm getting mine on Friday the 8th. when I go to work, oh, uhh, I mean shopping...
Logged
Janitore
Guest
« Reply #24 on: December 07, 2006, 06:53:55 pm »
Since were discussing presses and such, what's the size of the threaded rod used for the Turret lug installation tool? and what angle is it ground to in order to get the correct flare on the lug?  Does anyone use anything else for this pupose?
Thanks.
Logged
punkykatt
Level 3
Offline Offline
I love tube amps
« Reply #25 on: December 07, 2006, 09:48:13 pm »
I used a 3/8" bolt, drilled a 1/8" hole dead center in the end about 1/2" deep.  Took another 3/8" bolt cut the head off, put it in a hand drill, turned on the bench grinder and while having the drill on I put a point on the end similar to a center punch. Your done,  works like a charm.  Punky 8-)
Logged
Gregory
Level 1
Offline Offline
I love tube amps
« Reply #26 on: December 08, 2006, 12:39:42 am »
I have a large floor model drill press. Its all the way on the other side of the shop and not well suited for small work.
Shadows from the drill head and my head are no help.
So I ground a center punch like this.
I can use a SMALL hammer right at my well lit desk.
The center pin works as a third hand.
Haven't used it alot yet, but the 100 or so I have done have been perfect.
A guy could still use it in a press.
« Last Edit: December 08, 2006, 12:43:07 am by gdstepp » Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
