Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 19, 2013, 07:24:56 am
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: rare national  (Read 272 times)
blues man
Level 2
Offline Offline
I hate solid state amps
« on: July 14, 2008, 03:42:06 pm »
Has anybody seen or know anything about this guitar?
« Last Edit: July 14, 2008, 03:47:24 pm by blues man » Logged
Fresh_Start
Level 4
Offline Offline
noob de Lux
« Reply #1 on: July 14, 2008, 03:58:54 pm »
That's a weird looking guitar - in a cool way!   8)
The body shape, and especially the f-holes, are pretty unique.
Wish I had an answer or two for you...
Instead I have a question - what does the knob on the lower/treble bout do?
You really ought to write "Vintage Guitar" about that National.  Even if they don't publish the answer, they might at least point you in the right direction.
Cheers,
Chip
Logged
Quote from: jjasilli
Quote from: PRR
blues man
Level 2
Offline Offline
« Reply #2 on: July 14, 2008, 04:02:42 pm »
The knob by the cut away is a master vol. Then it has 2 vol and 2 tone controls with the lead pickup a bass roll off on the tone control.
Logged
billcreller
Level 4
Offline Offline
1934
« Reply #3 on: July 14, 2008, 07:21:20 pm »
  I still have a National flat top, #1155 , that I bought new in 1950. Still a nice guitar. A buddy bought an archtop the same year, National #1100 "Aristocrat".  It has one neck pickup, and blonde finish.
Oh yeah , still have the National amp that I bought with it.
  Yours is an unusual guitar, and I think very rare.  First I have seen.
Logged
I'm still tryin' to figure this out........
blues man
Level 2
Offline Offline
« Reply #4 on: July 14, 2008, 09:56:09 pm »
I have probably spent 20 hours searching the net on this guitar and found absolutely nothing. Ive owned it since 1984.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
