Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 20, 2013, 11:20:49 am
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Anyway for a Dry/Mix thingamabob for Analog pedals  (Read 200 times)
Terry
Guest
« on: June 23, 2008, 07:48:44 pm »
I've got 5 nice analog pedals and that wont change.  But I do lust after the dry/mix feature in digital crap.  Anyway I can have my cake and it it to?  A dry/mix system for my analog pedals with out eating up signal.
Logged
birt
Level 3
Offline Offline
I love tube amps
« Reply #1 on: June 24, 2008, 04:06:28 am »
check the "panning for fun" article at geofex.com
that should help you a lot.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
