Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 24, 2013, 05:21:28 pm
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Tim Wallis and Tommy Emmanuel  (Read 261 times)
Dynaflow
Level 4
Offline Offline
Have a cow man!
« on: April 08, 2008, 06:46:04 am »
 I ran across this guy while I was looking at B bender tele stuff. He makes a unit which drops B and G strings which goes around your arm on the right side. He also has a string drop deal you'll see him use. I was quite blown away by him. Thought I'd share:
And since I posted over the rainbow on that last clip, here's another tremendous version by Tommy Emmanuel (This guy is a monster)
Warning this next clip may make you re-evaluate your playing. Seriously...
Regards,
Dyna
« Last Edit: April 08, 2008, 06:55:06 am by Dynaflow » Logged
Ritchie200
Level 3
Offline Offline
Smokin' 88's!
« Reply #1 on: April 08, 2008, 09:53:48 am »
Tommy WOW! :o
Check THIS out...
Logged
My old man is a television repairman, he's got this ultimate set of tools!-Spicoli
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #2 on: April 08, 2008, 12:05:15 pm »
 Yeah, the dude is scary. :D probably one of the best steel string acoustic players I've seen (at least right up there no question).
Regards,
Dyna
Logged
Geezer
Global Moderator
Level 4
Offline Offline
Groov'n Tube'n KOOK (Keeper Of Odd Knowledge)
« Reply #3 on: May 09, 2008, 08:19:28 am »
Here's early Tommy E....a different side, for sure.
And I really like this......
« Last Edit: May 09, 2008, 08:27:31 am by da_geezer » Logged
tubenit
Global Moderator
Level 5
Offline Offline
Life is a daring adventure or nothing at all!
« Reply #4 on: May 09, 2008, 08:59:54 am »
Wow!  That's impressive!
Logged
JerryErickson
Level 1
Offline Offline
I love tube amps
« Reply #5 on: July 14, 2008, 07:18:54 pm »
The Tommy Emmanuel clip of "Somewhere Over The Rainbow" is from a webcast. The website is:
http://www.woodsongs.com/showlist.asp
It might be from show #428, he's been on there a few times. There's a lot of good stuff on there!
Tim Wallis is from Warrensburg,IL around Decatur,IL. He's a talented guy,and he'll tell ya':). I think I
heard that Planet Waves might be picking up his d-tuner thing.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
