Screws-Nuts-Washers Lamps-Diodes-Channel Switching Screws-Nuts-Washers Transformers
Switches Wire-Cable-Heat shrink Tube Sockets Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Tube Sockets Jacks-Plugs-Connectors Handles-Amp Trim Parts
Reverb tanks and Bags Pots-Knobs Jacks-Plugs-Connectors Tube Sockets
Switches Transformers Circuit Board Building parts Jacks-Plugs-Connectors
Pots-Knobs Resistors Fuse Holders-Cords-AC Items Wire-Cable-Heat shrink
Lamps-Diodes-Channel Switching Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Pots-Knobs
Pots-Knobs Screws-Nuts-Washers Tubes-Valves Chassis-Boxes
Pots-Knobs Foot Pedals Pots-Knobs Handles-Amp Trim Parts
Foot Pedals Tube Sockets Pots-Knobs Circuit Board Building parts
Misc Hardware-Grommets-Feet-Ring terminals Pots-Knobs Tubes-Valves Pots-Knobs
Fuse Holders-Cords-AC Items Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching Switches
Misc Hardware-Grommets-Feet-Ring terminals Books Jacks-Plugs-Connectors Switches
Lamps-Diodes-Channel Switching Tools and Batteries Transformers Switches
Chassis-Boxes Pots-Knobs Tools and Batteries Capacitors
Tube Sockets Transformers Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Fuse Holders-Cords-AC Items Capacitors Circuit Board Building parts Capacitors
Screws-Nuts-Washers Switches Foot Pedals Bike Light Parts
Tools and Batteries Handles-Amp Trim Parts Tubes-Valves Jacks-Plugs-Connectors
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Tubes-Valves
Transformers Lamps-Diodes-Channel Switching Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Screws-Nuts-Washers Tools and Batteries Resistors
Handles-Amp Trim Parts Circuit Board Building parts Lamps-Diodes-Channel Switching Tubes-Valves
Tube Sockets Tools and Batteries Resistors Tubes-Valves
Guitar Strings Misc Hardware-Grommets-Feet-Ring terminals Capacitors Transformers
Pots-Knobs Tube Sockets Capacitors Tube Sockets
Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Circuit Board Building parts
Resistors Bike Light Parts Jacks-Plugs-Connectors Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 25, 2013, 07:27:09 pm
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: greetings from nashville tn  (Read 196 times)
Dblues
Level 1
Offline Offline
« on: March 16, 2012, 10:07:46 am »
Hi All,
    44 year guitar student wanting to learn more about amps. I've built a few pedals and am about to finish my first guitar build. This looks like a great place to get started.
Dennis
Logged
Shrapnel
Level 3
Offline Offline
glowing bottles are kewl
WWW
« Reply #1 on: March 16, 2012, 02:10:17 pm »
Hi All,
Dennis
This is a great place to get started. Your pedal experience is good background. Remember the dangers of line voltage and above and practice safety and you'll be hooked on rolling your own amps as much as the rest of your equipment.
Logged
-Later!
 -Bill.
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
