Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 19, 2013, 06:32:04 pm
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Tube Preamp Build Ideas?  (Read 459 times)
1911A1
Guest
« on: September 02, 2007, 01:34:33 pm »
I just bought an 80s or 90s TG Raxx preamp and want to gut it and put something else inside it. I looked at 84's tube preamp, but he says it's not a switchable distortion type thing. I've put a Matchless Hotbox in it already and have ripped that out (too farty and mushy in the low end-I guess the web-based schematics were correct). Does anyone here have any suggestions on a good-sounding preamp that they have TRIED? I have two 12AX7 types to play around with. I'm looking for a good drive but not necessarily metal. Thanks for the info, Pike.
Logged
thermion
Level 2
Offline Offline
Repeat Of Fender
« Reply #1 on: September 13, 2007, 01:39:49 pm »
there is a schematic in the library for a pretty straight-forward tube preamp with 2x 12ax7. it states it's not a distortion box but looking at the schematic there are a few places where you could bilk a little more gain out of a given stage. try sovtek 12ax7lps for maximum bark. it's a nice design and the cascading of the stages will help you get the sound you're after.
Logged
1911A1
Guest
« Reply #2 on: September 13, 2007, 04:22:47 pm »
Thanks, Thermion.  The preamp you're mentioning was the one I was talking about. I haven't heard this particular preamp so I was wondering how it sounds. Thanks again for the input, Pike.
Logged
EL34
Administrator
Level 5
Offline Offline
wooot!
WWW
« Reply #3 on: October 10, 2007, 03:10:01 pm »
The pre amps, rack and pedal on my library page do not clip or overdrive like a distortion pedal.
I use the preamp for recording.
The guitar sound that comes out of the preamp is real warm and clean and that goes right into the line in on my computer sound card.
You can get a bit of grit by cranking it all the way up but it's not real nice sounding distortion.
You just need to find a preamp design from some amp that has multi stage overdrive and copy that, although that might be more than two 12ax7's?
Logged
jerrydyer
Level 3
Offline Offline
Make it one of a kind
« Reply #4 on: October 10, 2007, 04:15:11 pm »
EL34 "You can get a bit of grit by cranking it all the way up but it's not real nice sounding distortion. "
I disagree. I think the tube pedal makes a great distortion. I've used it maxed into a stereo effects processor, into the powr section of a 2204. Its killer.
Logged
1911A1
Guest
« Reply #5 on: October 10, 2007, 07:09:25 pm »
Thanks guys. I think I'm gonna try a 2204 or something like that.
Thanks again EL,Therm and Jerry
Regards, Pike.
Logged
EL34
Administrator
Level 5
Offline Offline
wooot!
WWW
« Reply #6 on: October 10, 2007, 07:41:37 pm »
I guess I meant that it is not a tube screamer type pedal distortion sound or any other distortion pedal type sound.
I guess it overdrives, but I don't use it for that.
I feed the nice warm tube pre amp signal into the computer and then use Guitar rig to color the signal with effects.
Logged
ampgeek
Level 2
Offline Offline
Viva La Tube!!
« Reply #7 on: October 19, 2007, 06:15:44 pm »
Any thoughts/experience on how Doug's stereo tube preamp would work with microphone level signals?
Thinking that it might be useful in those cases where you want to stick a mic on a speaker to include it's flavour in the signal path.
TIA,
Dave O.
Logged
EL34
Administrator
Level 5
Offline Offline
wooot!
WWW
« Reply #8 on: October 22, 2007, 01:18:00 pm »
I have used my stereo tube pre amp many times with a SM57 for voice.
I just plugged into it with a 1/4 hi-lo z adapter
Logged
ampgeek
Level 2
Offline Offline
Viva La Tube!!
« Reply #9 on: October 23, 2007, 11:13:19 pm »
Excellent!
Sounds like that lends significant flexibility to the design.  Thinking about not only home recording but live sound support as well.  I have been toying with the following:
guitar---->non-time based effects----->tube amp---->mike on speaker in isolation box---->stereo pre amp (bridged input)---->EQ---->time based effects---->power amp---->speakers
Lots of stuff but I already have most of it.  Just needs some creative packaging to keep it manageable.
Should be able to create some excellent stereo effects even in a small venue!
Thanks Doug,
Dave O.
Logged
EL34
Administrator
Level 5
Offline Offline
wooot!
WWW
« Reply #10 on: October 24, 2007, 08:24:19 am »
I have a Palmer PGA-04.
http://palmergear.com/
No mics, no speaker box, sounds real good but is pretty expensive.
You feed the amp load into it, tweak the knobs to get a great line level signal which you can send to a board/pa or use for home recording.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
