You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum
June 19, 2013, 12:51:26 pm
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
Media
Login
Register
Other Stuff
Guitars
(Moderators:
Geezer
tubenit
PRR
sluckey
Tele neck on Strat body... how-to?
Pages: [
1
Go Down
« previous
next »
Print
Author
Topic: Tele neck on Strat body... how-to? (Read 482 times)
bluesbear
SMG
Level 3
Offline
I love tube amps
on:
August 30, 2007, 02:20:07 pm »
I was always under the impression that Strat and Tele neck pockets are identical. Well... I just bought a Tele neck for my Strat. It seems that Strat necks are rounded at the end and Tele's are square! You can put a Strat neck on a Tele but not the other way around. Am I correct in assuming that the corners of the neck pocket on the Strat have to be squared off for the Tele neck to fit? If there's more to it, does anyone know how it's done?
Dave
Logged
rob440
Level 2
Offline
I love tube amps
Re: Tele neck on Strat body... how-to?
Reply #1 on:
August 30, 2007, 06:32:16 pm »
The neck pockets are the same depth the diffence being the radius so yout tele neck wont go deep enough into your strats body. Theres two options you could sqaure the strats pocket to fit the neck. or put the strat radius on the tele neck. Which piece is more valuable? I think thats a 7 1/2'' rad in the end of a strat neck. Probably the easiest way is to get a neck pocket routing template, not the one from stew mac as I believe its oversized, and do the body. If your neck has a fingerboard extention you could sand the radius with a belt sander after marking it out with a homade template, or maybe make a masonite template and route the radius on the neck. I hope this helps and makes sense, show us the results of your telestratser when your done.
Logged
tubenit
Global Moderator
Level 5
Offline
Life is a daring adventure or nothing at all!
Reply #2 on:
August 31, 2007, 05:39:13 am »
Rob440 gave you the right answer.
It's not a big deal getting these to match. You simply either have some routing or sanding to do. I would lean towards sanding and rounding the Tele neck personally because I think it's easier. I used a dremel tool and emory board.
I went thru the same thing buying a Warmoth Tele neck to fit on my Tele which has the neck cutout set up for a strat.
Be sure you seal the small amount of exposed wood with lacquer or urethane. Small artist brush will do it for you.
Obviously your concern is intonation and a nice tight fit into the neck cavity. When I was done the intonation was excellent. No problem.
Tubenit
Logged
heresrobert
Level 1
Offline
Reply #3 on:
August 31, 2007, 09:47:15 am »
Dave,
From a wookworking perspective, it would be easier to reshape the neck as apposed to repocketing the body. Rob440 hit it right on with his thoughts. Sight unseen, I would use 1/4 or 1/2" hard board and shape the exact fit that you want for the heel. I would also put in the screw holes. Next would be to use a good amount of double stick tape and press the neck to the HB/masonite. Check your alignment and screw holes several times. You only have one chance. On a router table use a straight cutting bit with a bearing on the bottom of the bit. Gently route your neck to the shape of the hardboard/masonite. A sharp bit and light passes are essential. I hope you have good wood skills. I did this to re-taper a bolt on neck that was too wide at the heel. Man was I stressed until it was done and verified accurate.
Robert
Logged
bluesbear
SMG
Level 3
Offline
I love tube amps
Reply #4 on:
August 31, 2007, 02:44:32 pm »
Hi. I have and can use a router but I'm a lot more confident with wood chisels (more experience). This body is chopped up anyway due to the fact I've used every combination of pickups known over the years. I'll look them over real close and decide which method will work for me.
Thanks!!!
Dave
Logged
jjasilli
Level 4
Offline
Took the power supply test. . . got a B+
Reply #5 on:
September 02, 2007, 09:41:56 pm »
Template & router is a good choice. But in my nearby thread - First Parts Strat - I did it with parts on hand: dremel tool in a router base; and makeshift template using a spare piece of 1/4" oplywood as a mask over the neck pocket, with side rails held in place with double sided tape.
I used a dremel bit the same diameter as a large diameter dremel bit shaft. I needed to make 3 passes at three different depths to get to the bottom of the neck pocket in the body. Set the depth of the bit for the first cut. With the dremel tool unplugged, place the bit against one side side of the pocket; abd set that side's rail agaionst the base of the router. Do the same for the other side. For the fron of the pocket, place the bit against the CENTER of te pocket; align the fraont rail against the base of the router The rails keep you from over cutting
Plug in the dremel tool; turn it on; run the router base along the rails and carve out a more square pocket. Check the neck for a test fit. When happy, lower the bit depth and cut again; then a third time to reach the bottom of the pocket. I used a small rounded sculptor's chisel to finish the shape of the curves.
This came out real well and I was able to use tools and materials on hand. And I'm no cabiney maker or luthier by any means. Templates are expensive, and like bluesbear I wasn't expecting this neck fitting issue; and don't plan to do it again.
Logged
jjasilli
Level 4
Offline
Reply #6 on:
September 02, 2007, 09:44:33 pm »
Logged
Pages: [
1
Go Up
Print
« previous
next »
Other Stuff
Guitars
(Moderators:
Geezer
tubenit
PRR
sluckey
Jump to:
Please select a destination:
Forum and Web site Stuff
=> Forum Issues and Information
=> Hoffman Amplifiers web sites
=> Introduce Yourself
=> Forum how to's
Amp Stuff
=> Tube Amp Building - Tweaks - Repairs
=> AmpTools/Tech Tips
=> Archives of favorite topics
=> Schematics and Diagrams
===> PC Express and JSchem - Schematics and Layout diagrams
===> Schematics
=> Hoffman amp Projects
=> Hoffman Board manufactures
=> EZ Board postings
Other Stuff
=> Cabinets-Speakers
=> Solid State
=> Effects
=> Guitars
=> Sound clips
=> Video Clips
=> LED Lighting
=> Other Topics
=> Your other hobbies
=> Buy - Sell - Trade
Loading...
click here for more info
