Reverb tanks and Bags Foot Pedals Wire-Cable-Heat shrink Capacitors
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Transformers Tubes-Valves
Lamps-Diodes-Channel Switching Tubes-Valves Screws-Nuts-Washers Pots-Knobs
Fuse Holders-Cords-AC Items Pots-Knobs Jacks-Plugs-Connectors Handles-Amp Trim Parts
Handles-Amp Trim Parts Capacitors Lamps-Diodes-Channel Switching Transformers
Tube Sockets Resistors Pots-Knobs Jacks-Plugs-Connectors
Foot Pedals Lamps-Diodes-Channel Switching Switches Tube Sockets
Tools and Batteries Wire-Cable-Heat shrink Transformers Transformers
Jacks-Plugs-Connectors Chassis-Boxes Chassis-Boxes Screws-Nuts-Washers
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Pots-Knobs
Tools and Batteries Jacks-Plugs-Connectors Pots-Knobs Circuit Board Building parts
Wire-Cable-Heat shrink Jacks-Plugs-Connectors Capacitors Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Resistors Jacks-Plugs-Connectors
Switches Switches Fuse Holders-Cords-AC Items Handles-Amp Trim Parts
Lamps-Diodes-Channel Switching Circuit Board Building parts Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Bike Light Parts Screws-Nuts-Washers Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals
Tube Sockets Tube Sockets Jacks-Plugs-Connectors Tubes-Valves
Lamps-Diodes-Channel Switching Circuit Board Building parts Handles-Amp Trim Parts Jacks-Plugs-Connectors
Capacitors Pots-Knobs Tools and Batteries Tubes-Valves
Tube Sockets Tube Sockets Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals
Tubes-Valves Pots-Knobs Fuse Holders-Cords-AC Items Tubes-Valves
Fuse Holders-Cords-AC Items Books Pots-Knobs Lamps-Diodes-Channel Switching
Guitar Strings Tube Sockets Resistors Jacks-Plugs-Connectors
Pots-Knobs Fuse Holders-Cords-AC Items Fuse Holders-Cords-AC Items Tools and Batteries
Screws-Nuts-Washers Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Switches
Transformers Foot Pedals Switches Pots-Knobs
Tube Sockets Switches Resistors Handles-Amp Trim Parts
Transformers Pots-Knobs Bike Light Parts Circuit Board Building parts
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum June 20, 2013, 12:11:23 am
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Hello from Greenville SC  (Read 326 times)
GvilleDave
Level 1
Offline Offline
« on: November 22, 2011, 03:50:37 pm »
Thanks in advance to all of you who will be (and have already through older posts) answering questions etc... as I start on my first amp build.  I have a background in construction and am a woodworker by hobby so the cabinet parts will be the easy part for me.  I have been interested in building an amp for a couple years and just recently started taking steps to make it a reality.  Step one - educate myself online and through books on basic electronics and amplification.  Step 2 practice building simple PCB circuits and test circuits to work on my soldering and basic technique.  Lastly I started thinking about the build itself and have decided on a Marshall style 18 watt w/ tremolo.  I have found through research online a schematic, layout and parts listing that all match, and have ordered all the components to go ahead and build the circuit board.  Mine will be a separate head & speaker cabinet.  So far it seems there is lots of online documentation on this type build but knowing that this is my first build I am sure I will hit many a roadblock between here and the finish line...  My plan is to go slow, take my time and enjoy the learning process.  Dave
« Last Edit: December 28, 2011, 10:14:16 am by GvilleDave » Logged
tubenit
Global Moderator
Level 5
Offline Offline
Life is a daring adventure or nothing at all!
« Reply #1 on: November 23, 2011, 05:24:15 am »
Welcome to the forum!  And I hope you'll enjoy your amp building hobby.
OldHouseScott is in Clover, SC.
I'm in Charlotte, NC.
with respect, Tubenit
Logged
stingray_65
SMG
Level 3
Offline Offline
« Reply #2 on: November 24, 2011, 08:19:04 am »
You found the right forum!
The guys here can work through just about any stumbling blocks you might come across.
Ray
Logged
GvilleDave
Level 1
Offline Offline
« Reply #3 on: November 28, 2011, 04:09:00 pm »
Thanks for the welcome.  Its nice to know I have experienced amp builders in the area to learn from.  I am excited to get started but not planning to get in a rush...
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
