Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 21, 2013, 07:21:58 pm
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: Hi to all.  (Read 464 times)
Octave
Level 1
Offline Offline
« on: March 03, 2011, 07:51:31 pm »
 Hey guys and gals. My name is Ben and I am new to this hobby. In the process of building a 5E3 circuit amp. It sounds great FWIW. Got an old RCA phono amp that only hummed loudly. Replaced all the caps and got hooked so I ripped it all out and started studying schematics that I could make work with what I had and the 5C3 and 5E3 fit closely. The phono amp came with 6cg7 preamp tubes which is why a tried the 5c3. Not sure why but it wasn't being very reliable. It would start humming unless the tone knob was all the way off or all the way up. It would go away with replacing v1 but after 6 v1 replacements in three days I gave up on the 5c3. I ordered new tube sockets and the resistors and caps to turn it into a 5e3. There is just more info on the net about the 5e3 too. I think though one day i'm gonna build a 5c3 with the 8 pin octal preamp tube. The 6cg7 was a cool tube to use though. When it worked it had very nice headroom and only a lite grind even at full volume. Not sure why the 5c3 failed cause i also worked on grounding while it was all apart and that improved my ohm readings all over the amp. Old aluminum chassis needed scuffing up to get decent grounds. Anyways I'm rambling.
About me, I'm a mechanic at a Nissan Dealership and I'm 30 years old. My guitar is a 1978 Gibson Les Paul Pro. It has seymour duncan p90 stacks. Bridge wired in series and neck wired parallel It's like having two different guitars. One day I think i'll wire in push pull pots to switch series/parallel on the fly. I have all the original equipment for it too. I don't have an amp for it anymore. In my younger rock n roll years I had a great Rivera Knuckle Head 120watt. It was awesome but after not touring anymore it was too much amp to sit in my apartment. Went to a Mesa Maveric 30watt twin and liked it a lot but sold it one year and its been years since I owned any other amp. Borrowed a Peavy amp from a friend a got the bug to own an amp again and now here I am building one. I'm Married and have a 6 year old girl. I play mandolin in a gospel band in Nashville for a church held in a Honky Tonk. Roberts Western World on broadway if anyone wants to attend :) Guess thats all for now ask anything you wish.
Logged
Ritchie200
Level 3
Offline Offline
Smokin' 88's!
« Reply #1 on: March 04, 2011, 09:38:52 am »
Welcome Ben!
A friend of mine owns a music store and he sold Rivera amps.  When visiting I would always play the Knuckle Head - what a great sounding amp!  It's hard to let the good ones go...  In another 10 yrs or so, you will be looking for a used one again!  Good luck on your latest build!
Logged
My old man is a television repairman, he's got this ultimate set of tools!-Spicoli
Octave
Level 1
Offline Offline
« Reply #2 on: March 04, 2011, 08:39:39 pm »
 Thanks for the welcome :)
Logged
Willabe
Level 4
Offline Offline
« Reply #3 on: March 04, 2011, 09:51:12 pm »
Ben,
Come on in an join a crowd!        wink
5E3 was my 1'st build, your gonna love that amp.
Good people here, very helpfull to all! Have at it, eat all you can eat, Did you know it's Mardi Gras?      laugh
Sorry, but to me that means spring is coming. Been a LONG winter here in Chgo.
      Brad        angel
« Last Edit: March 04, 2011, 10:00:14 pm by Willabe » Logged
Ritchie200
Level 3
Offline Offline
Smokin' 88's!
« Reply #4 on: March 04, 2011, 10:44:22 pm »
Now I know who to email for problems with my Murano! laugh
Logged
Octave
Level 1
Offline Offline
« Reply #5 on: March 07, 2011, 12:56:43 am »
haha i can help best I can on the murano.
Not sure If i should post this here or start a new thread somewhere else but here goes. My 5E3 build
How it started
rewired
plugged in and works
made the cabinet
rounded the corners
covering
need to order hardware now
with guitar
Logged
Willabe
Level 4
Offline Offline
« Reply #6 on: March 07, 2011, 10:50:17 am »
That looks realy nice! Very nice work!
          Brad         smiley
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
