Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 21, 2013, 12:03:06 am
Login with username, password and session length
   Home   Help Search Media Login Register
Pages: [1]   Go Down
  Print
Author Topic: slide guitar bridge setup?  (Read 333 times)
johno
Level 1
Offline Offline
I wonder what this does?
« on: August 09, 2007, 03:20:07 am »
howdy,i recently broke my arm in a car crash and i cant play any more so ive set up my spare guitar as a slide guitar.its an ibanez iceman,yeah i know "funny slide guitar"but it sounds cool and i can still play and thats the main thing.ive lifted the nut with a piece of angle line over the top of the nut and lifted the bridge way high.what i was wondering was how do i setup the bridge saddles for the harmonics as its about 5mm from the bottom of the 6th string to the fret board.perhaps it doesnt matter abot harmonics as im not fretting the strings anyway.any info on this subject would be helpful.
        johno
Logged
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #1 on: August 09, 2007, 08:02:45 pm »
 Not required for slide, its tuned open and any little bit its out is just a slight adjustment of the slide to get it in pitch (since slide is basically a move it till it sounds right kinda thing). Sorry to hear about your mishap, on the positive side you'll get your slide chops together! :D
Regards,
Dyna
Logged
Geo
Level 3
Offline Offline
I'm actually caucasian.
« Reply #2 on: August 09, 2007, 08:36:42 pm »
As I think Dyna said, you don't need to fiddle with the intonation at all. For slide, the frets basically don't exist under the strings.
I hope this isn't permanent for you.   :(
Logged
When I was a kid we played cowpersons and native americans.......
johno
Level 1
Offline Offline
« Reply #3 on: August 09, 2007, 11:01:46 pm »
thanks for the info. yeah this slide thing is pretty cool.ive stumble over quite few riffs and sounds in a g tuning"oh thats how they get that sound". having lots of fun and healing slowly
        regards johno
Logged
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #4 on: August 10, 2007, 12:10:12 am »
 Try a open E tuning too, a and d string tuned up a whole step g tuned up a half step (just play a E and you'll see where they need to be raised). Good for Elmore James and that sort of thing, good fun.
Regards,
Dyna
Logged
Geo
Level 3
Offline Offline
« Reply #5 on: August 10, 2007, 09:28:33 am »
You might want to use extra light strings if you're going to go tuning up. You'll break strings that way. At least, that's what happened to me.
Logged
Dynaflow
Level 4
Offline Offline
Have a cow man!
« Reply #6 on: August 10, 2007, 07:56:53 pm »
 I run 10's and 11's and if they're reasonably fresh and you have no bridge issues it can usually take it... (but broken strings do happen... :D )
Regards,
Dyna
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
