Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 21, 2013, 03:02:24 am
Login with username, password and session length
  Home Help Search   Media   Login Register
Album
jojokeo's amplifiers
Album - Owner: jojokeo - 9 items
There's no clone amps here. Everything is of my personal whims inspired by many on this forum which I greatly appreciate and admire for their generous sharing of info, contributions, and willingness to help others. Thanks also Doug, you rock!
Items view: Normal view Filestack view
Sort by: ID Date Title Views Rating | Sort Order: Ascending Descending
Tiny Giant
Tiny Giant was along the same lines as some of my other low powered chassis-type amps only this is the lowest output one yet at a whopping 1.1 watts. I had a very small PT sitting on a shelf for a long time and finally put it to use. This was a great exercise in pushing my skills further in that it…
Aug 12, 2011
Wildcat
Wildcat - A S.E. design using a KT77, KT66, EL34, or 6L6GC w/ power scaling VVR for Master Level/Volume control. The preamp can utilize any 12a_7 tube and has a unique 3-way voicing switch that simultaneously biases multiple stages using authentic "Marshall", "Fender", or "Vintage" values for gain &…
Jan 22, 2011
Tweed Super DeLuxe
V1 can be ran in series or parallel w/ Treb, Bass & Volume/Gain controls, has tone stack filtered bypass to control low end when in this mode > LTPI > PPIMV & Presence which can be switched in or out all into an Emminence Red Fang.
Apr 22, 2011
DumbleWatt
My Dumble-style designed preamp: Vol w/ Tweed tone control biased alternately towards saturation then cut-off which switches and cascades into OD section using same biasing techniques w/ Gain Treb Bass & 3-way voiced mid EQ switch and sharing a Master Vol for both going into an 18 Watt-style PA, swi…
Aug 12, 2011
Little Giant
Little Giant is a 2w-4w pratice amp that came at a time BigDaddy was in need of a small amp for his situation but couldn't build any longer. He made it clear a tone stack was mandatory so I added this and give him credit as it is better than only a simple tone control. We had animosity through this…
Sep 05, 2010
The Sheriff JRG800 Plexi
A Marshall in Fender's clothing :)
A lower wattage, smaller, and lighter gig friendly verison cross of a JCM800 and Plexi design in a combo. Originally inspired by my old JCM800 stack packing in new twists and options using 6V6s. Hammond & Mercury iron, extra gain controls & switching, fixed and/or…
Aug 20, 2009
Cherrybomb
The Cherrybomb amp was inspired originally by Geezer's Little Wing and HoSo56 along with my C-4 Heritage Special amp. V1 is a 5879 w/ pentode/triode switch, v2 = 12ax7, into PA consisting of 6bm8s for the pi and output tubes. The Boost switch bypasses the CF stage which also has Merlins suggested ti…
Jan 25, 2010
AC4 AC15 Heritage EF86 Tube Amp Custom Built like Dr Z & Vox.wmv
Evolution of one of my first ef86 amps
Something different, a video of photos of the various building and arduously painful re-building phases along w/ a song I quickly made from the amp after it's final completion several years ago.
Jun 26, 2011
Firecracker amplifier build - my Firefly inspired version.wmv
Firecracker amplifier build - my Firefly inspired version wmv
Another build in the fun low wattage category I call Firecracker inspired by the Firefly amp that uses two 12ax7s in cascode mode & a 12au7 except my circuit has different values, a little different circuit, and uses a 12bh7a. However, it can use the 12au7 and even a JJ ecc99 also for different outp…
Aug 12, 2011
Aeva Media 1.4w © 2008-2011 Nao & Dragooon - Wedge: level up your forum!
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
