6G6B with reverb
Here is a 6G6B circuit,one channel with reverb added.
Posted by phsyconoodler
Sep 26, 2012
princeton reverb,15" with high gain module
princeton reverb with high gain module like a Top Boost module for an AC 30. Pine cab,15" Weber Alnico speaker.
Does Fender-Marshall tones and everything in between.
May 19, 2011
DRRI hand wired
Here's a DRRI I hand wired.Sounds quite a bit better than stock.
Apr 08, 2011
Posted by whittele
Mar 23, 2011
Posted by whittele
Mar 23, 2011
Dumbleator Clone
Tube buffered effects loop to use with Overdrive Special clone
Posted by Structo
Mar 22, 2011
Dumble Overdrive Special Clone 100w
This is a clone of a Dumble Overdrive Special 100w amp head. This is mated to a 2x12 with two EVM 12L Classic speakers.
Posted by Structo
Mar 22, 2011
Protozilla
This is Protozilla V2. This is my vacuum tube proto-board. The circuit is a 2 channel microphone preamp using 6SL7's, 6SN7's, and Cinemag I/O transformers.
Posted by RicharD
Mar 12, 2011
Butter Pre Phone
6DJ8 preamp/headphone amp. This is what hangs off my PC.
Posted by RicharD
Mar 12, 2011
Death Star
AC30 Top Boost the size of a letter
Posted by overtone
Mar 07, 2011
Tweed BluezMeister small combo
One of my favorite amps. D-type cathode biased Geezer design.
Posted by tubenit
Mar 05, 2011
Oh My!
A mad scientist's experiment.Two high-powered Princeton Reverbs in one combo.One side with 6L6's and the other with EL34's.
Rating: 5.00
Feb 23, 2011
70's ODS Style build
Here's a 70's style ODS scratch build I did a few years back. I used a D'Lite chassis and powered relays for foot switching
Posted by m3moser
Feb 23, 2011
Brownface Pro replica
Here's my feeble attempt at a replica of this rare amp
Posted by m3moser
Feb 23, 2011
Brownface Pro Original
I recently built a Brownface Pro for a client . It sounds great- here is an original
Posted by m3moser
Feb 23, 2011
Blackjack Gut Shot
Parallel V1 Fender Tone Stack with Switchable Raw Control Cathodyne PI Fixed Bias 6V6 5G9 Tremolo
Posted by Boots Deville
Feb 20, 2011
The famous Rivera concert 2 rats nest
Posted by JayB
Feb 19, 2011
Posted by JayB
Feb 19, 2011
Silver TV 5E3
Made from an Altec Hi-Fi amp, with 6AX5 rectifier, Altec Iron, Weber cabinet, vintage tubes, skinny knobs, Doug supplied chassis and most of the rest of the parts. Celestion Vintage 10 speaker.
Posted by P Batty
Feb 18, 2011
Deluxe Reverb build
This one is a Deluxe Reverb build.Stock.
Feb 18, 2011
Princeton Reverb from scratch
Here's a PR that I built from scratch.The only item I bought is the chassis.
Feb 18, 2011
Original Princeton Reverb - Power Amp & Tube Sockets
Posted by Fresh_Start
Feb 18, 2011
Original Princeton Reverb - Bias Board
Feb 18, 2011
Original Princeton Reverb - Preamp
Feb 18, 2011
Original Princeton Reverb - Full Inside
Feb 18, 2011
UberVerb Gut Shot
Straight AB763 for Vibrato channel, but "Normal" channel is not normal. Brown Vibroverb tone stack, guitar/harp switch and various other tweaks.
Feb 16, 2011
Posted by navdave
Feb 16, 2011
