Reverb tanks and Bags Foot Pedals Wire-Cable-Heat shrink Capacitors
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Transformers Tubes-Valves
Lamps-Diodes-Channel Switching Tubes-Valves Screws-Nuts-Washers Pots-Knobs
Fuse Holders-Cords-AC Items Pots-Knobs Jacks-Plugs-Connectors Handles-Amp Trim Parts
Handles-Amp Trim Parts Capacitors Lamps-Diodes-Channel Switching Transformers
Tube Sockets Resistors Pots-Knobs Jacks-Plugs-Connectors
Foot Pedals Lamps-Diodes-Channel Switching Switches Tube Sockets
Tools and Batteries Wire-Cable-Heat shrink Transformers Transformers
Jacks-Plugs-Connectors Chassis-Boxes Chassis-Boxes Screws-Nuts-Washers
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Pots-Knobs
Tools and Batteries Jacks-Plugs-Connectors Pots-Knobs Circuit Board Building parts
Wire-Cable-Heat shrink Jacks-Plugs-Connectors Capacitors Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Resistors Jacks-Plugs-Connectors
Switches Switches Fuse Holders-Cords-AC Items Handles-Amp Trim Parts
Lamps-Diodes-Channel Switching Circuit Board Building parts Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Bike Light Parts Screws-Nuts-Washers Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals
Tube Sockets Tube Sockets Jacks-Plugs-Connectors Tubes-Valves
Lamps-Diodes-Channel Switching Circuit Board Building parts Handles-Amp Trim Parts Jacks-Plugs-Connectors
Capacitors Pots-Knobs Tools and Batteries Tubes-Valves
Tube Sockets Tube Sockets Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals
Tubes-Valves Pots-Knobs Fuse Holders-Cords-AC Items Tubes-Valves
Fuse Holders-Cords-AC Items Books Pots-Knobs Lamps-Diodes-Channel Switching
Guitar Strings Tube Sockets Resistors Jacks-Plugs-Connectors
Pots-Knobs Fuse Holders-Cords-AC Items Fuse Holders-Cords-AC Items Tools and Batteries
Screws-Nuts-Washers Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Switches
Transformers Foot Pedals Switches Pots-Knobs
Tube Sockets Switches Resistors Handles-Amp Trim Parts
Transformers Pots-Knobs Bike Light Parts Circuit Board Building parts
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum June 19, 2013, 08:12:51 am
Login with username, password and session length
  Home Help Search   Media   Login Register
Home
Welcome to the Hoffman Amplifiers Media Gallery
Recent Items
Items view: Normal view Filestack view
Sort by: ID Date Title Views Rating | Sort Order: Ascending Descending
Dual preamp and eq amp
Built this one for my buddy Richard two different amps in one box point to point wired.
Posted by navdave
Feb 16, 2011
in Misc Amp Images
BASS AMP
200 watt-ish bass amp sporting Marshall Major spec iron not in the head shell.
Posted by navdave
Feb 16, 2011
in Misc Amp Images
Navtone Amp
First amp I ever built.
Posted by navdave
Feb 16, 2011
in Misc Amp Images
1st "champ"
Posted by jeff967
Feb 16, 2011
in Misc Amp Images
The Sheriff
A Marshall in Fender's clothing huh
Inspired by my old JCM800 stack w/ a few twists. Hammond & Mercury iron, extra gain controls & switching, fixed or cathode bias, pentode/triode modes, switched presence, variable line out, send/return, Eminence Wizard or Vintage 30
 Rating: 5.00
Posted by jojokeo
Feb 15, 2011
in Misc Amp Images
Random Items
6G6B with reverb
Here is a 6G6B circuit,one channel with reverb added.
Posted by phsyconoodler
Sep 26, 2012
in Gut Shots
pict0016
Posted by stratman_el84
Jun 27, 2011
in Testament 30
6V6
Baltic birch and a little cherry.  Looks like a ding on the front, but its just the grain.  Grill is burlap laminated chicken wire.  EF86, 6V6 PP with effects loop.
Posted by loogie
Feb 19, 2011
in Misc Amp Images
RZC 5E9-A
RZC 5E9-A.
Based on 1954 Fender Tweed Tremolux.
15W, 6V6 pair, tube rectified. Head only
Posted by rzenc
Jan 24, 2011
in RZC Labs
DSC02285
Posted by Bub
Sep 02, 2011
in KOC 5F6-A
Recent Comments
In DSC02272 By EL34 Sep 04, 2011
Total Items: 192
Total Albums: 16
Total Comments: 1
Aeva Media 1.4w © 2008-2011 Nao & Dragooon - Wedge: level up your forum!
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
click here for more info
