Handles-Amp Trim Parts Foot Pedals Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Capacitors Transformers
Jacks-Plugs-Connectors Wire-Cable-Heat shrink Pots-Knobs Foot Pedals
Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts
Screws-Nuts-Washers Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Pots-Knobs Pots-Knobs Pots-Knobs
Tools and Batteries Misc Hardware-Grommets-Feet-Ring terminals Transformers Switches
Handles-Amp Trim Parts Switches Jacks-Plugs-Connectors Pots-Knobs
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Capacitors
Tube Sockets Pots-Knobs Pots-Knobs Switches
Tubes-Valves Circuit Board Building parts Jacks-Plugs-Connectors Handles-Amp Trim Parts
Capacitors Circuit Board Building parts Jacks-Plugs-Connectors Tubes-Valves
Switches Capacitors Chassis-Boxes Tubes-Valves
Tube Sockets Switches Tube Sockets Resistors
Lamps-Diodes-Channel Switching Guitar Strings Resistors Books
Circuit Board Building parts Circuit Board Building parts Screws-Nuts-Washers Lamps-Diodes-Channel Switching
Transformers Circuit Board Building parts Wire-Cable-Heat shrink Jacks-Plugs-Connectors
Tools and Batteries Fuse Holders-Cords-AC Items Pots-Knobs Pots-Knobs
Wire-Cable-Heat shrink Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching Tubes-Valves
Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Pots-Knobs Pots-Knobs
Foot Pedals Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Tubes-Valves Bike Light Parts Chassis-Boxes Jacks-Plugs-Connectors
Bike Light Parts Reverb tanks and Bags Tools and Batteries Jacks-Plugs-Connectors
Tube Sockets Tubes-Valves Transformers Resistors
Capacitors Screws-Nuts-Washers Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Tube Sockets Transformers Resistors Tube Sockets
Tools and Batteries Transformers Switches Tube Sockets
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 21, 2013, 04:18:39 am
Login with username, password and session length
  Home Help Search   Media   Login Register
Home
Welcome to the Hoffman Amplifiers Media Gallery
Recent Items
Items view: Normal view Filestack view
Sort by: ID Date Title Views Rating | Sort Order: Ascending Descending
Talisman
2 channel Fender Marshall mix, effects loop. 50 watt.
Posted by JayB
Feb 19, 2011
in Misc Amp Images
Silver TV 5E3
Made from an Altec Hi-Fi amp, with 6AX5 rectifier, Altec Iron, Weber cabinet, vintage tubes, skinny knobs, Doug supplied chassis and most of the rest of the parts. Celestion Vintage 10 speaker.
Posted by P Batty
Feb 18, 2011
in Gut Shots
Silver TV 5E3
TV front Deluxe in Silver Levant
Posted by P Batty
Feb 18, 2011
in Misc Amp Images
ROCKOLA 18 Watt 6L6G
ROCKOLA 18 Watt 1956 RCA 6L6G / 6SN7,6SL7,
Posted by plexi50
Feb 18, 2011
in Misc Amp Images
Splawn Quickrod Clone
Posted by Tone Junkie
Feb 18, 2011
in Misc Amp Images
Random Items
Dual preamp and eq amp
Built this one for my buddy Richard two different amps in one box point to point wired.
Posted by navdave
Feb 16, 2011
in Misc Amp Images
Death Star
AC30 Top Boost the size of a letter
Posted by overtone
Mar 07, 2011
in Gut Shots
RZC REAPER80
80W, 4x6L6GC output power tubes.
Preamp tubes:
V1-12AY7;
V2-ECC83;
v3-ECC83.
Clean preamp with James-type tonestack + post eq. O.D. stage.
Posted by rzenc
Jun 10, 2011
in RZC Labs
IMG 3273
Original 50 Watt Hoffman Head in Black Powdercoat
Posted by EL34
Jun 08, 2011
in EL34's Amp images
Nirvana
This one is an experimental one that began in 2009 as a project for a friend who wanted the Dumble sort of topology. 2x5881 cathode biased, VVR and reverb. Ragin' Cajuns in the head and G10Cs in the extension cab. Wormy Maple. Glad I don't have to move it around.
Posted by zendragon63
Mar 01, 2011
in Misc Amp Images
Recent Comments
In DSC02272 By EL34 Sep 04, 2011
Total Items: 192
Total Albums: 16
Total Comments: 1
Aeva Media 1.4w © 2008-2011 Nao & Dragooon - Wedge: level up your forum!
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
