Screws-Nuts-Washers Lamps-Diodes-Channel Switching Screws-Nuts-Washers Transformers
Switches Wire-Cable-Heat shrink Tube Sockets Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Tube Sockets Jacks-Plugs-Connectors Handles-Amp Trim Parts
Reverb tanks and Bags Pots-Knobs Jacks-Plugs-Connectors Tube Sockets
Switches Transformers Circuit Board Building parts Jacks-Plugs-Connectors
Pots-Knobs Resistors Fuse Holders-Cords-AC Items Wire-Cable-Heat shrink
Lamps-Diodes-Channel Switching Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Pots-Knobs
Pots-Knobs Screws-Nuts-Washers Tubes-Valves Chassis-Boxes
Pots-Knobs Foot Pedals Pots-Knobs Handles-Amp Trim Parts
Foot Pedals Tube Sockets Pots-Knobs Circuit Board Building parts
Misc Hardware-Grommets-Feet-Ring terminals Pots-Knobs Tubes-Valves Pots-Knobs
Fuse Holders-Cords-AC Items Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching Switches
Misc Hardware-Grommets-Feet-Ring terminals Books Jacks-Plugs-Connectors Switches
Lamps-Diodes-Channel Switching Tools and Batteries Transformers Switches
Chassis-Boxes Pots-Knobs Tools and Batteries Capacitors
Tube Sockets Transformers Lamps-Diodes-Channel Switching Fuse Holders-Cords-AC Items
Fuse Holders-Cords-AC Items Capacitors Circuit Board Building parts Capacitors
Screws-Nuts-Washers Switches Foot Pedals Bike Light Parts
Tools and Batteries Handles-Amp Trim Parts Tubes-Valves Jacks-Plugs-Connectors
Fuse Holders-Cords-AC Items Tube Sockets Handles-Amp Trim Parts Tubes-Valves
Transformers Lamps-Diodes-Channel Switching Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Screws-Nuts-Washers Tools and Batteries Resistors
Handles-Amp Trim Parts Circuit Board Building parts Lamps-Diodes-Channel Switching Tubes-Valves
Tube Sockets Tools and Batteries Resistors Tubes-Valves
Guitar Strings Misc Hardware-Grommets-Feet-Ring terminals Capacitors Transformers
Pots-Knobs Tube Sockets Capacitors Tube Sockets
Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching Wire-Cable-Heat shrink Circuit Board Building parts
Resistors Bike Light Parts Jacks-Plugs-Connectors Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello, you are a guest in the Hoffman Amplifiers forum May 25, 2013, 11:04:17 pm
Login with username, password and session length
  Home   Help   Search Media Login Register
The profile screen in the default theme normally consists of a single main pane, with an additional menu to the left to lead you through the editing options for your own profile. Please note that, because an SMF forum may be customized extensively by its administrator(s), the features and user permissions described here are typical rather than definitive.
To edit your own profile, start by selecting Profile from the main menu or clicking your own username. You can also view (but not edit) other members' profiles by clicking on their names.
  1. Information Normally Available to all Members
    1. Profile Info
  2. Settings Normally Available to Profile Owners
    1. Modify Profile
    2. Actions
  3. Settings Normally Restricted to Admins
    1. Profile Info
    2. Modify Profile
    3. Actions
Profile Info
  Username: Member's login name Picture/Text
Name: Member's screen name
Posts: Member's number of posts
Position: Member's member group or post group
Date Registered: Date and time of registration
Last Active: Date and time last active
ICQ:
AIM:
MSN:
YIM:
Email: member@their.address
Website:
Current Status: Online Online
Gender:
Age: N/A
Local Time: Current date and time in member's time zone
Language:
Signature:
Additional Information:
Send this member a personal message.
Show the last posts of this person.
Show general statistics for this member.
  • This Summary screen is not only there to tell you about others, but also the first screen that you see when editing your own profile.
  • Members may choose to hide their email address and/or online status.
  • The fields left empty here are not filled in by default, so you should edit your profile if you wish to display this information.
  • You can send the profile owner a Personal Message by clicking the Current Status On/Offline Icon or following the link from Additional Information below.
  • Show the last posts of this person links to a complete paginated listing of the member's posts.
  • Show general statistics for this member links to a screen of statistics about the member's time online and posting activity.
While the Summary screen is the same as the one shown above and the Show Posts and Show Stats links are effectively duplicates, profile owners are also provided with the tools to customize their own profiles:
Modify Profile
  • Account Related Settings enables you to make changes to your display name (your login or username can only be changed by an administrator), preferred language (if the forum administrators have installed alternative language packs), email and password settings.
  • Forum Profile Information enables you to enter optional personal details such as gender, birthdate, location, website and instant messenger contact information. It's also where you go to enter your own personal text and signature and select an avatar (personal picture) from a list (if provided by the forum administrators) or link to one of your own on the web.
  • Look and Layout Preferences enables you to select your preferred theme (forum skin), time zone and format and other personal choices for layout settings. Note that the currently selected option in the menu pane is highlighted in bold type:
Profile Info
Summary
Show Stats
Show Posts
Modify Profile
Notifications and Email
Personal Message Options
Actions
Delete this account
   Edit Profile
This section allows you to customize the look and layout of the forum.
Current Theme: Forum or Board Default (change)
Time Format:
Help The format here will be used to show dates throughout this forum.
Time Offset:
Number of hours to +/- to make displayed time equal to your local time.
(Current forum time should be displayed here.)
Show board descriptions inside boards.
Show child boards on every page inside boards, not just the first.
Don't show other user's avatars.
Don't show other user's signatures.
Return to topics after posting by default.
Show most recent posts at the top.
Show most recent personal messages at top.
First day of the week on the calendar:
Use quick reply on topic display:
Show quick-moderation on message index as
  • Notifications and Email enables you to select personal preferences for notifications (emails about new topics/replies) and lists any notifications that you have set up.
  • Personal Message Options enables you to set up an ignore list (blacklist) for Personal Messages, to request notification of new PMs by email and to save copies of your outgoing PMs by default.
Actions
  • Delete this account does exactly what it says! Yes, there's a confirmation screen, but it really does delete your own account, so be careful...
As well as being able to view/edit any of the details above from other members' profiles, some further options are normally visible to (and executable by) admins only:
Profile Info
Summary
Show Stats
Show Posts
Track User
Track IP
Show Permissions
Modify Profile
Actions
Ban this user
Delete this account
Profile Info
  • Track User provides a list of IP numbers used by the member, other members who might be in the same IP range and error messages generated/experienced by the member.
  • Track IP provides tools for tracking members, messages and errors from any specified IP range.
  • Show Permissions lists the board permissions that have been granted to the member and who gave them.
Modify Profile
  • Account Related Settings is basically the same screen as shown to profile owners, but with the additional option to assign members to member groups.
  • Forum Profile Information is basically the same screen as shown to profile owners, but with the additional option to specify custom titles for members.
Actions
  • Ban this user provides tools for banning users, configuring the level of the ban and maintaining a ban list noting the details of any bans in force.
  • Delete this account is similar to the screen of the same name available to all members, but the confirmation question is different when it's not your own account that's about to be deleted.
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
